Need help with a 4l60-E please
Old 03-12-2005, 07:16 PM
ChevPower's Avatar
Default Need help with a 4l60-E please
Problem is the tranny does not down shift with you move the selector from od to 3rd or 2nd, If i'm running around 50mph and pull the selector into 2nd and give just a bit of throttle it feels like nutral but if i throttle down it pulls, and if i put the selector in first and take off to about 20mph and let off the gas it does not engine brake the rpm just fall back to idle, If the selector is in OD it feels normal no problem at all, all upshift feels good and from a stop a WOT run shifts normal. If some can give some input please do
