Speedo Correction w/ TH400
Old 03-23-2005, 09:34 AM
cgfirehawk's Avatar
Default Speedo Correction w/ TH400
Wasn't sure where to post this but here goes. I have a 97SS w/ TH400 and LT1 Edit and I can't get the speedo corrected enough. Edit will only let me go up to a 4.96 gear ratio and I'm still 20mph off. Any help would be great!
Old 03-23-2005, 11:16 AM
Ragtop 99's Avatar
can you change the tire size in the program?
Old 03-23-2005, 11:23 AM
strokedls1's Avatar
We changed the tire size and the gear ratio in ls1 edit to get the speedometer to read correctly. In LS1 edit we have it as a m6 tranny and used gear size=6, and tire size= 16.4. He had 4.10 rearend gears, and standard th400 gearing.
