automatic tranny problems
Old 08-17-2005, 12:01 AM
RedRider81's Avatar
Default automatic tranny problems
On my way home while in 'D' my car seemed to qucikly redline on the freeeway while going about 95. I slowed down and third gear seems to be all but gone (works til about 3k rpms then quickly redlines and i go nowhere). When accelerating, the car shifts from one-two-and part of three, then the rpm's climb and i can't accelerate anymore. All the other gears work (R, 1, 2,). The gears that don't are partly 3 & Drive (only 1-2-3partly). I ended up taking home the side roads and driving in 2 staying under 45 mph. Is my tranny totally screwed? I'm pretty uneducated when it comes to tranny's and i have no idea if it's just that gear or if the problem lies deeper with the whole tranny. BTW, my car has a 2800 converter & tranny cooler. I have heard ideas from a stuck valve to pcm problems. I'm just trying see how bad my situation is and if i should consider getting a new tranny or try and fix my existing one. Thanks for any insight guys.
Old 08-17-2005, 04:15 AM
cablebandit's Avatar
sounds like the 3/4 clutch pack is gone to me
Old 08-17-2005, 07:30 AM
Import Patrol
CrawlinWS6's Avatar
my suggestion is this, if you plan on mod. your car, don't throw money down the drain on a stock tranny, just bit the bullet and upgrade to something stronger
