My luck is getting worse somehow
Old 09-07-2005, 06:14 PM
Richiec77's Avatar
Default My luck is getting worse somehow
Looks like the Main input shaft bearing or TC is going fast. 4L60E. Century built.
I took a hard right turn to get out into traffic. It went fine but then made a pop and a feeling like beeing totally disengaged and I heard a Whine. At 1st I thought the Eaton POSI had finnally blow itself out (about to be replaced with a spool here soon), but when I gave it a little gas at the light the car moved so I thought it might be OK for now.
Now. When I gave it gas it rev's up to Red-line and won't shift. It also has a High pitched whine like that of a Turbo (bearings) and it will only shift if I let off the gas. The TC still locks up and I still need to drive it around and get some other symptoms, but I think the Trans Input Shaft bearing is shot.
About to check the fluid in a little bit to smell it and to see what else might be in the fluid. Seems Shot to me.
Old 09-07-2005, 06:18 PM
Richiec77's Avatar
Ok. Nothing in thefluid and it doesn't smell burnt. It still whines in Park but not as much as Driving. I think the trans is done for.
Looks like the Front pump can go out also.
Old 09-07-2005, 09:07 PM
Richiec77's Avatar
OK. Maybe not the Pump. Or the TC. I have no Reverse. I didn't notice it before beacuse I brought it straight home. Tried to back out of the driveway and it's no go. ****.
Old 09-08-2005, 12:14 AM
ACW
ACW's Avatar
Here's some possibilities
Vibration in Reverse and Whining Noise in Park
Oil Pump
- Chamber in pump body rotor pocket
First Gear Range Only - No Upshift
Control Valve Body
- The 1-2 Shift valve is sticking
- The spacer plate or gaskets are mispositioned or damaged
Case
- The case to valve body face is damaged or is not flat
Shift Solenoid Valves
- Stuck or damaged
- Faulty electrical connection
2-4 Servo Assembly
- The apply passage case is restricted or blocked
- Nicks or burrs on the servo pin or on the pin bore in the case
- Fourth servo piston is installed backwards
2-4 Band Assembly
- The 2-4 band is worn or damaged
- The band anchor pin is not engaged
No Reverse or Slips in Reverse
Input Housing Assembly
- 3-4 Apply ring stuck in applied position
- Forward clutch not releasing
- Turbine shaft seals missing, cut or damaged
Manual Valve Link
- Disconnected
Valve Body Assembly
- 2-3 Shift valve stuck
- Manual linkage not adjusted
- Spacer plate and gaskets incorrect, mispositioned or damaged
- Lo overrun valve stuck
- Orificed cup plug restricted, missing or damaged
Reverse Input Clutch Assembly
- Clutch plate worn
- Reverse input housing and drum assembly cracked at weld
- Clutch plate retaining ring out of groove
- Return spring assembly retaining ring out of groove
- Seals cut or damaged
- Restricted apply passage
- Porosity in piston
- Belleville plate installed incorrectly
- Excessive clutch plate travel
- Oversized housing
Lo and Reverse Clutch
- Clutch plates worn
- Seals damaged
- Return spring assembly retaining ring mispositioned
Quick Reply: My luck is getting worse somehow
