buying a z28 with a4
Old 09-08-2005, 04:33 PM
TAdriven98's Avatar
Default buying a z28 with a4
I am getting a z28 with an a4, around 70k miles, never had an auto ls1 what do i need to look for or listen for to know if its in good shape?
Old 09-08-2005, 04:51 PM
Anniversary "Z"'s Avatar
Pull the tranny dipstick smell it does it smell burnt, see if there is any rust looking dust on the dipstick (burnt clutches). Drive it and see how smooth the shifts are. Kick it down a couple times and make sure those are smooth. Notice at what RPM it shifts and if they are consitent or does the tach jump up in between gears. If the car is stock I'd be surprised if there is much to worry about, but those are the things I would look at.
Old 09-08-2005, 05:29 PM
TAdriven98's Avatar
yeah the car is stock
Old 09-09-2005, 07:54 AM
Ouija's Avatar
Obviously check for any slippage in the tranny, if you have to goose it to get it to go, that's bad. Doubt that will be the case, but in case you didn't know it's not normal. Should have good throttle response, shouldn't act like it's "spooling up."
