M6 to th350 swap in S10, need info
I know this is probably been beat to death, but i didn't feel like sorting through the hundreds of posts that come up when you search for "th350 swap". I was wondering if anyone had any info on the parts i'll need to do the swap, i got the crossmember and driveshaft under control but i need help on the rest. Im using a M6 computer and a custom engine management harness.
Corrent me if im wrong, but the M6 computer doesn't need a VSS signal right? I already know im going to be throwing just about every trouble code the ECU can throw at me without having any of the smog stuff and the wrong tranny. I basically just need the info needed to bolt the th350 up to the LS1 and get the thing rolling, such as flywheel, converter, and any spacers or adapters that i might need. Also keep in mind im trying to do this as cheap as possible, so $1K custom converters are out of the question. I already have a full manual valve body th350 to use, so thats taken care of.
