Is a B&M 24k GVW cooler enough for a 5000 stall converter?
Old 09-22-2005, 06:36 PM
9 Second Club NA
Dragaholic's Avatar
Default Is a B&M 24k GVW cooler enough for a 5000 stall converter?
I used to have a PT4400 swapped over to a Protorque converter, should have around 5000 stall speed. Just wondering if I needed a bigger cooler? Thanks.
Old 09-23-2005, 03:03 PM
Ragtop 99's Avatar
With your race weight, I assume that you cleared out the A/C and get good air flow to your cooler. It should be adequate unless you get to hot lap the car
Old 09-23-2005, 03:09 PM
9 Second Club NA
Dragaholic's Avatar
Good airflow to the cooler, a/c is out, raceweight should be 3000 lbs. or less.
Old 09-23-2005, 03:37 PM
GREATWALLTA's Avatar
WOW your set up is mind boggling, I bet that thing launches like a rocket. If you want to make sure to get the most cooling, get your self one of those big tranny cooler that has a electric fan attached to it.
