Need part numbers for replacement seals
Am changing the torque converter in a 99 4L60E & would like to replace seals in the process. The rear bearing seal & the pump seal are two that are in mind. Are there any others of significance & does anyone know where part numnbers for the seals can be found? Thank-you
