4l60e...will an '05 fit a '96 blazer?
Old 09-29-2005, 11:26 PM
fourZ's Avatar
Default 4L60E question...can i put a '05 trans into a '96 blazer?
i have a bad transmission in my '96 blazer, a 4L60E, and i can get one out of a 2005 chevy (seller doesn't specify make and model)...simply put, will it work without major alterations?
Last edited by fourZ; 09-30-2005 at 11:03 AM. Reason: make it shorter and more concise
Old 10-02-2005, 07:55 PM
fourZ's Avatar
anybody? a little help?
Old 10-02-2005, 09:10 PM
Import Patrol
CrawlinWS6's Avatar
Is your blazer a 4x4 is the 05 chevy a 4x4? Because if one does have a transfer case, then the internals of the transmission are different. If they both are 2wd then u should be fine, if they both are 4wd then you should be fine too. But if ones a 2wd and ones a 4wd, its not worth it.
Old 10-04-2005, 11:12 AM
fourZ's Avatar
mines a 4x2, i think his is too...but ran out of money anyways...thanks
