Stalling/idle problems with aftermarket converter?
Old 10-04-2005, 09:39 AM
MattZ28's Avatar
Default Stalling/idle problems with aftermarket converter?
Hey all,
I have a '96 Z28 and recently installed a race built 4L60E with a Pro Torque 3200 lockup stall.
I've read quite a few posts online about people having problems with their cars wanting to stall after installing a converter, and I am having the same issue.
The symptoms are as follows:
Closed loop, operating temperature, only in gear, if I tap the gas and let off, the RPMs will drop to ~300 and bounce back up/down for a few seconds and finally level out. The car stalled on me when I tapped the gas backing out of my driveway. This only happens at very low speeds.
Anyone have any idea as to what it could be?
I'm thinking maybe since there's more slippage/RPMs per TPS %, maybe the PCM is trying to adjust via the IAC?
Old 10-04-2005, 09:52 AM
Bryan @ Speed Inc.'s Avatar
i have the same problem with my car. it's intermittent. only if i let it sit a long time, then if i drive the car it will be fine for the rest of the day. i'll start it, it will search for the idle between 500-1,200 rpm for a few seconds... sometimes i have to hold the rpm above 1,000 rpm for a few seconds then it will come down and idle steady........ this is a trans problem? it makes sense cause it only started happening AFTER converting my 6spd to a t-400 car. anyone have info on this?
Old 10-04-2005, 03:20 PM
gator's 99TA's Avatar
all you need is tuning. the small convertor doesnt put enough of a load on the motor.
Old 10-04-2005, 03:27 PM
Joel_SS's Avatar
Mine does the exact same thing.. On cold starts it is fine, but hot starts it will hunt for the idle and sometimes die.. But after driving for a few minutes idle is fine.
Old 10-04-2005, 04:17 PM
2001NBMZ28's Avatar
My idle would hunt/car die sometimes at low speed after the Vig install - raising the in gear idle fixed it - got tired of putting it in neutral when stopping at a light when it would act up.
Old 10-04-2005, 06:04 PM
MattZ28's Avatar
Thanks guys. Sent my PCM to my tuner yesterday so I'll tell him what to do.
Old 10-04-2005, 07:20 PM
radz282003's Avatar
750RPMs was a nice idle for me.
Old 10-15-2005, 12:57 PM
MattZ28's Avatar
Ion from Madz28.com fixed it mostly. It still sorta does it, but nowhere near as bad.
Old 10-15-2005, 03:22 PM
2001NBMZ28's Avatar
Mine too, Predator reads 762-785.
Old 10-19-2005, 10:06 AM
TWISTEDTA's Avatar
I think a Dyno tune would take care of all your problems
Old 10-19-2005, 10:57 AM
12secSS's Avatar
A dyno tune would not alleviate idle issues. Depending on the software used to tune the car, you should be able to adjust the stall variables of slighly bump up the base idle by 50-100 rpms. No more than that is needed. The IAC has nothing to do with it, it is because (as posted) there is less rotating mass load on the engine so it cannot easily control the light weight conditon to set the idle to.
