Pump questions?
Pump questions?
what would be typical symptoms of the pump going out of a TH350?
My tranny is very slow on part throttle shifts, and wont downshift on its own. (no its not a manual valve body).
any insight would be great. Thanks
Originally Posted by jxaxsxoxn
Low pressure, take a pressure reading.
Dropping out of gear.
Pause before it moves in selected gear, especially reverse.
Originally Posted by Pro Built Automatics
The downshift cable (on a TH350) when setup correctly, should give you downshifts at 2/3 - 3/4 throttle.
there is no kickdown cable on mine. The downshift im referrering to is when i slow to a stop, i could leave it in 3rd and it would drive like a normal auto. Now it just stays in 3rd.
If you now take off in 3rd & it used to take off in 1st, then you most likely have a stuck governor and or sticky shift valves. This can happen when metal starts to get into the valve body and or governor.
