who runs the fuddle with spray?
Looking to pick up a fuddle stall. what STR should i go with and will there conv handle a 200shot? Looking to run some were around 500rwhp and 560rwtq on this conv.
Well, couple things you can do here. You can wait and see what kind of responses you'll get on your post which may confuse you..
Or you can call John at fuddle and get his advice. Most of the members on this board with automatics have converters, I think, so they can give you their recomendations.
John, however, builds converters for many types of vehicles at different levels of performance. Those are the best two choices as I see it.
Happy converter hunting!
Originally Posted by gator's 99TA
i have. went 1.473 60' on a 150 shot on drag radials and i make about 340 rwhp on motor alone. car is 3500 lbs. i have the 3600 2.2 str 245mm converter. HP/Street
do a search under my name and that 60' and you will see my write up.
also call fuddle racing.
coo thanks
Originally Posted by Ragtop 99
John: Are you locking the converter in 3rd under the spray?
