What TC's to use for TH350 & LS1?
Old 12-01-2005, 10:28 PM
Restricted User
CAT3's Avatar
Default What TC's to use for TH350 & LS1?
Is there a special LS1 TH350 TC, or will any TH350 TC work? I may need a short term limper to get me by if I need to send my ATI in for repair, dont want to break the bank doing it though. Thanks
Charlie
Old 12-01-2005, 11:13 PM
SUX2BU's Avatar
as long as your flexplate has holes for an old school converter to bolt up you can use any converter. the nose won't go into the crank but mine doesn't anyways. no problems here.
Old 12-02-2005, 12:02 AM
Restricted User
CAT3's Avatar
Your pilot is not in the crank area? Does it at least extend into the flexplates pilot hole?
Old 12-04-2005, 04:08 PM
1badA3Z's Avatar
u can try this place called redneck converters,they sell cheap but good converters,jmo
Old 12-04-2005, 04:43 PM
Yank's Avatar
I have seen converters come out of the car and it will cut the car in half and even hurt people when installed like that.
You have a time bomb !!! the flexplate will not contain the converter by itself ,and you will also loose your front pump on the trans even if it stays in place by some chance
Old 12-05-2005, 05:06 AM
Shinsetsu's Avatar
pm me their info please
Old 12-05-2005, 01:38 PM
sprayinss's Avatar
pm sent shinsetsu
