Stall questions
Stall questions
Ok, a 224/224 lsa 14 and some lt's are goin in soon. Right now my car reaches full power by 3000rpms?I want to keep it daily drivable especially since it is right now. I was gonna go w/a 3000 stall. Since I make full power by 3000rpm should I stick w/a 3000 stall or go higher. Also which stall specifically should I get and how much do they run?
Everyone i know will tell you to choose as least a 3500 Stall....
I know for me, i am running a Comp Cam's 232/ 236 .595 .601 @ 114 and run a Yank SY 3500...
I am thinking of going up to a 4000....
Great for daily driving..
My car dynoed @ 390hp & 380 ft lbs of torque... not too bad for a A4..
Good luck with your choice..
3500-3600 will be perfect for your set up..
I would go higher. I went with at 3200 to start and it was fine for a while. But you'll want more eventually, 3500 is pretty good for a daily driver.
As for which one, I would recommend Fuddle racing, they are a good price and John can help you pick the best for your needs.
