Question? Trouble with rebuilding on 4T60E GM Transaxel
I have rebuilt a 4T60E GM Transaxel and upon rebuilding it and putting it on the dyno the transmission neutrals out between third and fourth. All other gears work (ie: P/R/N/1st/2nd/3rd/Overdrive), do any of you have an idea of what could be causing this problem? I need an answer or response as soon as possible. Thanks
This happened to me once, and once I figured out what I did, I never made that mistake again! When tightening down the valvebody bolts, there is one 13mm bolt that pulls the 4th clutch housing toward the channel plate. I left it finger tight (got pulled off the job halfway through) and it caused symptoms like yours.
