Problems associated with underdrives in a4 tranny
what are the problems associated with using a underdrive in a a4 with cam and headers??? trying to decide to get one for my daily driver.
I'm running an underdrive w/ a pretty big system. I just can't crank the sounds for
any length of time idleing, it will discharge. But for a more normal stereo system go
for it!!!!!!!!!!!!!!
Hawk
Hawk
2 simple solutions 1. raise the idle, with a bigger then stock cam chances are its already higher then stock. 2. get an overdrive alt pulley, and no you really wont loose power to the ground with one(it takes 2 hp to turn a 100amp alt under full load)
