98'Z28 LS1, hypertech -Shift points??
This should probably be in PCM, or in Automatic Transmission.
Does hypertech use MPH or RPM? If it's RPM, then tie it to the torque curve. If it's MPH, you have to work backwards from your rear axle ratio.
Depends on where your rev limiter is going to be too. Don't want to be banging against that.
