4l60 question
Old 02-24-2006, 03:46 PM
goodolboy32's Avatar
Default 4l60 question
My friend has a 98 formula auto and hes debating on what type of kit to go with if he stays with 4L60. Any suggestions on good shift kits on the market? Thanks
Old 02-24-2006, 09:41 PM
Restricted User
Automatics's Avatar
The "modified" Trans-Go Performance Shift kit that I use, will give you smooth part throttle shifts (which is easy on the gear train) and quick & firm shifts at WOT (this will keep the band & clutches alive). If the shift kit is done right (matched to the rear end gear ratio, motor, torque converter, & how you drive) it can have long lasting beneficial effects.
Old 04-03-2006, 09:29 PM
Default thanks
thanks for the help guys ill let him know!
