shifter mounting& trans cover
Old 02-28-2006, 09:31 PM
D'scamaro's Avatar
Default shifter mounting& trans cover
i have a pistol grip hurst shifter and was wondering how you mounted your shifter and if you used your stock console?? and any pics would help a lot if possible thanks
and what trans sheild should i use for my t-350 a sheild or blanket, because i would think the blanked would be pretty heavy and which one would be easier to intall thanks a lot
Old 03-02-2006, 02:52 PM
D'scamaro's Avatar
help me out fellas, do you screw in the shifter or dril holes and use nuts and bolts?? thanks
