turbo 350
turbo 350
i have made this post in the lt1 section but only had one person to reply what i wanna know is if any one has went from a m-6 6speed to a turbo 350 and picked up on their track times or lost time becouse i am thinking of converting to the turbo 350 but i do not want to slow the car down any
thanks
thanks
i was on et streets with 13psi with the 1.7 had 4.11 gears in the 9 inch i installed drag lunch springs adjustable pb and 3.70 gears with et drag radials at 20 psi the last time when i went but hoped extremly bad and cut a 1.8 60
thanks brad
thanks brad
got them to i also have spohn floor mounted ta the only thing ireally dont have is relocation brackets and a good set of drag shocks for the rear i did order the relocation brackets yesterday any good shock oppinoins
thanks brad
thanks brad
