Low mile new trans, min mods to help it hold up
Old 03-18-2006, 07:38 PM
slick1851's Avatar
Default Low mile new trans, min mods to help it hold up
Ok im buying a wrecked TA soon, it was a very very low miles GM transmission. Im going to go with a Yank 3,200 and pick up a shift kit and transcooler, and run some good fluid.
Since this is a new tranny and not going to be a DailyDrive whats the bare min that should be done to it?
I plan on spraying a 150shot and going with a decent sized cam on the stock heads etc
Old 03-18-2006, 09:00 PM
slick1851's Avatar
Since the trans is new, it should hold up for a good period of time. I just want to improve some Key points, im on a Budget so any help would be great guys thanks!
Old 03-19-2006, 06:58 PM
Red Heartbeat's Avatar
If you're on a budget and can't afford to rebuild the transmission I would not even bother putting a performance converter in it. The converter is going to put undo stress upon the transmission. It makes if perform a lot better but it generates a lot more heat and stress upon all the parts.
