Driveshaft size needed TH400!!!!
Old 04-10-2006, 07:15 AM
n20stroker's Avatar
Default Driveshaft size needed TH400!!!!
Hey guys need some help here. Changing my m6 to a th400 short tail. I have a steel driveshaft that im going to make shorter does any one know what to cut it down to.
thanks
Old 04-10-2006, 09:51 AM
mvonada's Avatar
I would recommend taking it to a good driveline shop for this work. Needs to be balanced after it is cut down.
Old 04-10-2006, 11:03 AM
n20stroker's Avatar
i was going to. Wanted them to cut it to the right size.
Old 04-10-2006, 11:12 PM
408WS6's Avatar
thanks
I believe you will need to make it longer not shorter. Its about 2-3 inches longer but you really need to measure from your output shaft to your pinion yoke. Any other way is just guessing and is risky.
Old 04-11-2006, 07:04 AM
n20stroker's Avatar
thanks just waiting for parts then it can go up.
Old 04-11-2006, 02:37 PM
strokedls1's Avatar
Try calling summit. Inland empire driveshafts builds one for that application. Summit sells it and it might have some specs with it on their computer.
