Royal Purple/Amount of Fluid?? A4 Goat
Doing a converter her in a few weeks. Was wondering.....
1. What is everyone's opinion on Royal Purple? Ive herd more good than bad. The bad being tranny slippage, more weear, etc...
-and-
2. How many quarts do I need to fill the converter plus tranny.
Thanks
-and-
Thanks
Restricted User
I have also heard mixed things about fluid useage in our cars...I stick with Dextron III, whereas Drew778 uses Type F. When I asked the trans builders about RP and RL, they suggested to not use them so I dont.
Fluid, converter I squeeze in 2 qts before install, and then filter swap requires another 4 or 5 total, but if only doing a TC and not touching the pan, 3-4 should be good, depends on how much you lose on removal and install. GL
Charlie
Charlie
