wats the stock line pressure?
hey guys on my 4l60e wats the stock line pressure?i guess theres one at idle and another WOT.my tranny has transgo vavle body work but then my acumilators are plugged up instead of using the transgo springs exc.now my tranny has been rebuilt 3 time in a 4 month period and its pissing me off the tranny guy tells me to raise my pressure wat do u guys think
4L60e line pressure
Drive, park or neutral OE pressure should read between 55-190psi. In reverse it should read between 65-325psi. Now these trannies use a pressure control solenoid that uses Amp increments to change transmission line pressure. That being said if you didn't know how the solenoid works. The line pressure will increase with reduced PCS Amps. In drive at idle with your shift kit, line pressure should be reading 70-90psi. Under full throttle in drive you should see 200-230psi. These are the pressures that we see on our transmission dyno and have a lot of good feed back with our customers. You really need to get a gauge on your trans to answer your question. However if the trans has been done 3 times in 4 months you got some issues going on. Good luck.
