Those with a3, big stall and 2.73`s-3.42`s!
I have just finished my cam (g5x3 on 114) /full bolt on project on my 00`ss camaro! I am now going to remove the 6 speed and installing most likely a th350 or possibly a th400. The question I have is how many of you guys/girls have an a3 with a big stall ~4000 w/2.73`s-3.42`s and 26-28 in. tires and a cam drive your cars daily or almost daily. Also what et and mph are you putting down, preferrablly close to full weight w/ some suspension mods like lower control arm relocation brackets, panhard rod, rear sway bar, etc. Also I tried to search but didn`t come up with anything good. Thanks in advance!
Restricted User
Full weight (kind of) TH350, 4000 stall (too ******* loose for my combo), had 3.23's and now 3.50 on 9" rear, ZR1 street tires, Daily driven to/from work 18mi one way, cruise it and race it. Motor runs made best of 11.57 @ 116mph w/ 1.6x 60'....140 shot netted 10.61 @ 127mph shitty 1.5x (those times were on stock 3.23, never ran clean on the 9").
Suspension: Tubular front K and Arms, HAL R's front w/ HAL Springs, Hal rears w/ stock springs, I had Relo brackets on my stock rear, BADZ LCA's, Spohn TA, SFC. Stock PHB and Sway Bar.
