problem removing transmission
Old 05-18-2006, 05:18 PM
Npak's Avatar
Default problem removing transmission
the transmission is catching on the floor of the camaro and only has like an inch of spline to comeo outta the torque converter. its a ls1 fbody, anyone got ideas
Old 05-18-2006, 05:38 PM
8a8mfh's Avatar
anyone got ideas
Never drop the transmission without the torque converter. Try lifting the front of the engine.
Old 05-18-2006, 05:49 PM
1FASTLS's Avatar
Disconect the battery drop the starter and remove the converter bolts and drop with trans.
Old 05-18-2006, 06:29 PM
Npak's Avatar
well it came out w/ the converter. the conv to flywheel bolts were torqued waaaaay too tight from the last dumbass owner. 44ft/lbs shouldnt have me lifting my whole body in the air when im losening the bolts.
Old 05-19-2006, 12:27 AM
DOUBT IT's Avatar
You'd be surprised. I broke a damn hardened allen wrench breaking the last bolt loose. You forget, it's only 44 ft/lbs, but that sumbitch is loctited to hell and back! GM was stupid for not using a regular hex-head bolt from the factory.
Old 05-19-2006, 12:47 AM
jeremymcclure's Avatar
use a sawzall and cut the floor out so you can "fred flinstone" it
yeah never remove a tranny without the converter
i agree with him that youd be surprised as in how tight the bolts can get or seem to get after a period of time heating up and cooling down.
good luck.
i bed fred flinstonin it will give you at least 5 more HP and if not it would look funny as hell....
ok im done i must be tired! LOL
