M6 to A4 wiring questions, as well as vac mod questions.
Ive been looking for an ss a4 car that runs low 11's on motor but here lately seems like there all 6 speed cars for sale. If i get a 6-speed car and convert it, im trying to see what route to go.
Ive already been through the sticky's on this and did searches with no luck. does anyone have a diagram to convert the interior harness over for the auto shifter prndl switch. what has to be done with the clutch pedal switch? i assume the neutral safety switch is tied into the prndl switch as well as back up lights.
Ide be puting a flt level 5 trans in it. if i do the vac modulation, can i use the main M6 harness? or will I not have tc lock up? thanks guys!
