OEM Flywheel to Aftermarket?
Well im building a new motor and im wondering if I should look into getting a new Flywheel. The one i have is from 1993 and its obviously a little worn.
Other than having a new part, what are the benifets of say an Aluminum Flywheel?
Or any other option for that matter?
Tony.
Tony.
Restricted User
You mean flexplate? You can get a lighter flexplate, but most I think opt for a SFI Certified one to help prevent cracking the plate on higher stalled, or higher output cars. TCI, ATI, Fidenza all make them, and not sure who else.
Originally Posted by Speed Density
Yea i ment flex plate.
Well my setup is a 396 LT1 with a 3200 stall.
Ive heard it helps the RPMs get going faster is that true?
