dies in any gear
Old 07-01-2006, 03:16 PM
funkymonkeys409's Avatar
Default dies in any gear
alrigth ive got a porblem. i blew my first 4l60e and just put another one in (i put the new one in myself). i thought i got everything in right but now when ever i put in into any gear (R,OD,D,2,1) it kills itself. any ideas what it could be. i only had my TC (yank 4000) flushed out, not rebuilt. anything will help, thanks.
ps... is there suposed to be any vaccum lines hooked up to it?
Old 07-01-2006, 05:20 PM
FLT
FLT's Avatar
Sounds like your tcc is applied. Probably a pump issue or a lockup solenoid that is stuck closed or plugged. I would contact your builder and tell him about the problems your having. Good luck, Vince.
Old 07-03-2006, 01:29 AM
i heard that i might have to program the tranny for that converter, any ideas on that?
just tryin to figure this out all the possibilities before i bring it in.
Old 07-03-2006, 05:10 PM
Predator T/A's Avatar
i would say just like above that you tcc is engaged or you Iac is screwed...the TCC act just like a clutch in a manual trans if it is locked in it will stall
