Yank 3000 Super Stock Converter
current setup on my 02 T/A
33k miles
pacesetters LTs
slp lid and bellow
TSP rumbler cat back w/catted y pipe
3:73 strange gears
no tuning yet
would this converter be good with my setup, im not looking for some masive HP just enough to hang with these S/C rustangs and lightings. i daily drive the car.
33k miles
pacesetters LTs
slp lid and bellow
3:73 strange gears
no tuning yet
I had a TT2800 and ended up going with a PT4000, I don't regret the change at all. I say if you are concerned with streetability then shoot for a SS3600 or so. These cars love higher converters.
the thing is i mainly do freeway driving, around 20miles a day, what about a 3200 stall. im doing around 2500 RPM at about 60-65 will the 3200 take the RPMs up higher, like i said i want a converter that can handle DAILY DRIVING and still kick *** at the track.i dont want to go higher than a 3200 stall.
Originally Posted by dug
On the highway the converter locks up. You can have a 6k stall and the rpms will be the same as long the converter is locked.
I have a 4k and as soon as it locks on the highway it doesn't matter anymore.
If your going to change the converter I would go with the SS3600. These lockup converters really make living with a higher stall much easier.
I started with a Yank 3000 and it wasn't enough, I ended up with a Yank ST-3500 which is perfect for me. My car gets 27 mpg on the freeway on long trips with the mods below.
Dee Jay
Dee Jay
If you dirve lots of highway you're gears will hurt you more than the tc, the tc won't bother your highway milage at all. In your position I would not be reluctant to get a 3600 or even 3800. I drive all city and I'm still going with a 3400 eventually.
thanks for everything i might go with the 3200 or 3400, is this something that ill feel straight out? i havent adjusted my shift points since the gear install will this mess it up even more?
If you play with the Mustangs on the highway you need a lot more stall. A 3600 is about the minimum. To get any help on the 2-3 upshift takes a lot of stall.
A 3600 with 2.0 to around 2.2 would do fine. If those 19" wheels have stick tires, a 2.5 STR would work too.
i wish they were sticky, there more like drifter tires i dont drift my car so please dont start ragging on this thread, american muscle all the way
ill be using some 15" MT for the track.
