manually lock torque converter?
Old 07-06-2006, 03:00 PM
SAM98WS6's Avatar
Default manually lock torque converter?
IS there a way to lock the torque converter for dynoing without a reprogrammer? In the buick turbos we just used a paper clip to jump two terminals in the ALDL terminal.
Thanks
Old 07-06-2006, 05:48 PM
DanZ28's Avatar
Yes there is. You need to find the right wire on the pcm and tap into it. Run that wire to one side of the switch and a ground to the other side of the switch and you can lock it whenever you want manually.
Dan
