4l60e wont go into gear
Ive got a 4l60e in my conversion. I started it up for the first time and attempted to put it into gear today. But nothing happens. Fluid is topped off. No fluid is pumping through the cooler. Any ideas whats wrong?
thanks
thanks
Originally Posted by Vince @ FLT
I believe that you need to remove your trans. When you installed it I believe that you broke the pump.
Whats involved with replacing the pump? Any special tools? Where is the best place to buy one?
thanks
We sell FLT performance pumps $295 with a $100 core charge. It includes machined pump and stator. New AC Delco rotor,slide,vanes and rings. Also has the sonnax high output slide spring, oversized p/r valve and performance boost valve. You need to call Doug @ FLT 1-630-350-7776. He does all the shipping and part orders. As far as specialty tools if you buy a fully assembled one you will only need some basic tools. It might be a good idea to have the tc checked out as well.
