Holes in TCI flexplate won't line up
Old 08-13-2006, 01:24 PM
ss_girl's Avatar
Default Holes in TCI flexplate won't line up
I'm swapping out my stock flexplate in favor of a TCI SFI approved one and 3 holes on the converter are like 1/2 a hole off. every other hole won't line up. does anyone else have this problem? Did I get a bad flexplate? I'm using a T400 tranny. I'm not sure if my stocker was drilled before I got it or not. Do I need a dual pattern? Thanks a bunch.
Old 08-13-2006, 09:32 PM
DanZ28's Avatar
I use the TCI with my TH400. It is a dual pattern flexplate, you sure it's lined up on the right set of holes? What TC do you have?
Dan
Old 08-16-2006, 08:40 PM
ss_girl's Avatar
I'm using a yank converter with 6 bolt tabs on it. Do I only use 3 of them?
Old 08-16-2006, 08:54 PM
DanZ28's Avatar
I believe so. You might have to drill the other 3 if you want to use them. They might come close to the other 3 holes on the flexplate though, I'm not really sure.
Dan
Quick Reply: Holes in TCI flexplate won't line up
