How to test a solenoid?
Old 08-22-2006, 03:54 AM
AceHaag's Avatar
Default How to test a solenoid?
is there a way to test a shift solenoid to verify that it is working before installing it?
Old 08-22-2006, 10:28 AM
86MonteSS's Avatar
i need to know too!
Old 08-29-2006, 02:24 PM
AceHaag's Avatar
Anyone?
Old 08-29-2006, 02:50 PM
joecar's Avatar
Momentarily connect the solenoid across 12V using a fused jumper wire.
Old 08-29-2006, 03:37 PM
JMBLOWNWS6's Avatar
If you know anyone with a tech 2 they can do the function test for you easy!
Old 08-29-2006, 11:06 PM
Cody Brooks's Avatar
the best way to test it is the alluminum block made to test them. install the solenoid onto it apply 30psi compressed air it will exhaust until 12v is applied. apply 12v for a short time if no air leaks during that time then the solenoid is good.
Old 08-30-2006, 11:15 AM
AceHaag's Avatar
thanks guys
