Torque specs for B&M tranny pan
Old 09-10-2006, 10:13 AM
Gregg1LE's Avatar
Default Torque specs for B&M tranny pan
I bought a used B&M aluminum deep tranny pan and was going to install it today but I have no clue as to what to torque the bolts to. I looked on thier site but no luck. Anyone know?
Also, what type of gasket sealer should I use (if any) on it?
Thanks!
Old 09-11-2006, 08:42 AM
12secSS's Avatar
12 ft/lbs.
I would recommend a rubber-type replacement over the cork type gasket.
It should have come with an instruction sheet. If you do not have it, I can forward you a PDF copy, let me know.
Old 09-11-2006, 09:52 AM
Gregg1LE's Avatar
Originally Posted by 12secSS
12 ft/lbs.
Thanks for the info, and yes I would like the PDF copy.
gregg1le@sbcglobal.net
Thanks !
Old 09-11-2006, 09:56 AM
01WS6er's Avatar
What ever you do do not use RTV. Trans fluid will destroy the RTV and cause a leak.
Old 09-11-2006, 10:59 AM
12secSS's Avatar
Sent!
Old 09-11-2006, 07:43 PM
Gregg1LE's Avatar
Thanks for all the help, guys....but from the instructions George sent me I found out that I'm missing the filter retainer and the pickup tube extension . I guess I'll have to get those before i install it.
Old 09-12-2006, 12:20 PM
Gregg1LE's Avatar
Thanks to George Lara, the parts I am missing are on the way to me. He is a class act.
