Budget tranny 700r4 help
I need some suggestions on what to do with my tranny. Its a 93 lt1 700r4 and i have no mods to the engine or tranny right now. I do have a t67 turbo putting down about about 450 rwhp at 6psi what would be a very strong reliable option to build up? Can i be safe with just a transgo kit or do i need something stronger. At the end il be around 600 rwhp if i plan to go all the way through. What will i need and what should i go with?
LS1Tech Sponsor
You will need a trans built at least like the one in the link bellow
www.performabuiltautomatics.com/prorace.html
__________________
Although we don't have 700r4's listed on our web page, we do build them. I would suggest a build like one our level 4 or 5 4l60e units. Your 93 700r4 trans is unigue for your vehicle due to the case connector and inturnal lockup wiring. The price will be less than 60e's because the valve body kit is a little cheaper and also the electronics. We are located in wooddale and all units are fully dyno tested. Let us know if there is anything we can do for you. Vince
