Going th350 and have a question about the flexplate.
Well I ordered a th350 with a torque converter for the ls1 flexplate, so will this bolt right up or will still need some sort of spacer? I thought you needed 2 different spacers when running a regular sbc converter, just not sure what you need with the 98 flexplate and a converter designed for the ls1. Thanks for any info.
I am running a TCI flexplate with a 10" PTC Converter with a LS1 pilot.As long as the converter is built or bought for a TH350 and has a LS1 Pilot it should bolt up with out spacers
BTLFEDSS
BTLFEDSS
