Help! 4l60e
Depends if you have the VERY long extension that makes unbolting the trans itself easy or not, and whether you have a lift, and whether you have air tools, and whether you run across any other areas that you have to stop and ask questions about.
In a shop, on a lift, with air, and with experience, it can be done in under 2 hours easily.
On the ground, hand tools, and stopping to take breaks and find answers, more like a weekend.
Be VERY careful not to pinch the wire harness when the trans is reinstalled.
