Transgo 4l60e-HD2-C Reprog kit questions
Old 12-09-2006, 12:30 AM
brybe's Avatar
Default Transgo 4l60e-HD2-C Reprog kit questions
It says holds manual 1st-3rd to any RPM and backshifts to gear you select. So does this mean when in OD it will still shift up and down normaly?
What are the differences between the A,B and C if any?
Old 12-09-2006, 12:56 AM
LS1Tech Sponsor
performabuilt's Avatar
Yes it will retain all auto shifts in the overdrive position
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 12-09-2006, 01:25 AM
brybe's Avatar
Not sure I understand the holding part. Does it mean the ecm won't override a selected shift. Lever in 1st will stay in first, lever in 2nd will shift from 1st at a stop into 2nd and hold then back to 1st when you stop. Lever in 3rd will shift from 1st at stop into 2nd then 3rd and hold then back down when you stop.
Old 12-09-2006, 05:18 AM
PBA
PBA's Avatar
Yes, exactly.
Old 12-09-2006, 07:33 AM
FLT
FLT's Avatar
The a,b,and c series is just is a production date.
Old 12-09-2006, 10:01 AM
brybe's Avatar
Thanks guys for helping me understand.
Quick Reply: Transgo 4l60e-HD2-C Reprog kit questions
