4l60E 94 and 95 different?
Old 12-09-2006, 10:23 PM
lt170chevelle's Avatar
Default 4l60E 94 and 95 different?
I just put a rebuilt 4l60e from a s10 blazer in my 94 z28.it seems to be slipping a little and shifting a little sluggish, considering i have a tune on my computer for firmer shifts.i noticed the connector had an extra pin and was a different colors. the 94 had pinkish yellow and the 95 has a green one. so i was wandering if there might be different wiring issues on the newer tranny?!? any help would definitely be appreciated.
thanks
mako
Old 12-09-2006, 11:12 PM
LS1Tech Sponsor
performabuilt's Avatar
THE 95 IS A PWM UNIT lockup will not work you vehical dosent have the wiring to operate the pwm solenoid , However this would not explain the sloppy shifts , It would only explain the absence of lockup , There is a work around for the PWM easily enough if you PM me as for the sloppy shifts asuming everything else is ok theres are two possibilites that come to mind ,
missing pump screen in side of pump body
bad PCS are likley
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 12-10-2006, 12:23 AM
so how hard is it to get to the pcs?
Old 12-10-2006, 01:32 AM
LS1Tech Sponsor
On What You Need Just Holler Tomorrow And Ill Send Them
__________________
Call 888-744-6542
Old 12-10-2006, 09:16 AM
Default how to redo tthe pmw in the 4l60e on 95 going to 94
just wanted to find out how to redo the pmw stuff on the 4l60e on my 95 tranny to work with my 94
