i think overdrive is goin out
Old 12-14-2006, 02:32 AM
hi_po_heads's Avatar
Default i think overdrive is goin out
i have a pro built 4l60e and a vigilante 3600 stall. my problem is when the trans warms up it seems to start slipping in o/d. the car revs up endlessly, but i can push the brake in and the revs will drop to about 700rpm and then when i give it gas again the trans doesn't slip for another mile or so down the road. i have no idea whats goin on. this tranny has about 10000 miles on it now.
Old 12-14-2006, 09:20 AM
LS1Tech Sponsor
performabuilt's Avatar
Are you setting any codes and do you think its actually fourth gear thats slipping or does it seem more like the converter clutch
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 12-14-2006, 02:09 PM
well the check engine light comes on maybe once a week, but only for a few minutes. im not sure what the converter clutch is and what it does. i noticed if you shift to drive and back to overdrive it doesnt slip for a few minutes also.
Old 12-14-2006, 03:21 PM
LS1Tech Sponsor
Well i would get it scanned first , and find out what the code it it maybe a random missfire code that can disable lockup so i would suggest getting it scanned then post the numbers ok ,
__________________
Call 888-744-6542
Old 12-14-2006, 07:22 PM
oner's Avatar
Yeah mine started doing the same thing after i installed my TCI 3500.
Old 12-14-2006, 07:49 PM
Tech Resident
ChocoTaco369's Avatar
did you just put in the stall? if you did, you may need to get the car tuned. sometimes the stock tune doesn't get along with an aftermarket converter. you may need to have the lockup mph raised also because the lighter converters tend to slip under low mph lockup from what i've heard.
