Need some help.
Old 12-15-2006, 01:17 PM
Vortech GTO's Avatar
Default Need some help.
My stock tranny burned up so i bought a used century trans from a member on here and I noticed that on the input shaft there is a hole in the middle the stock one has something in it and the century has nothing should I swap the piece into the new trans or not and what is it. I am also using a 3000 stall converter if that makes any difference. Any help will be greatly appreciated.
Stock Input Shaft End
Century Input Shaft End
Old 12-15-2006, 01:26 PM
LS1Tech Sponsor
performabuilt's Avatar
Dont worry about the ecapusulated checkball it does not need to be there , so the empty hole is fine , dont swap it over its better without it
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
What was it put there for?
Old 12-15-2006, 01:28 PM
LS1Tech Sponsor
its slows lockup engagment makes it smoothe not what you want in a performance aplication
__________________
Call 888-744-6542
Old 12-15-2006, 01:30 PM
Thanks for the quick response.
Old 12-15-2006, 02:00 PM
LS1Tech Sponsor
no problem
__________________
Call 888-744-6542
