T400 Swap. Which Converter Flexplate
Old 01-17-2007, 10:41 PM
dnkynrbk's Avatar
Default T400 Swap. Which Converter Flexplate
I have the TCI flexplate for the ls1 and I do not want to use spacers is there a stall and which one are you guys running that will bolt right up. thanks
Old 01-18-2007, 12:19 AM
dnkynrbk's Avatar
anyone look through the FAQ and couldnt find an answer.
Old 01-18-2007, 08:51 AM
LS1TECH Sponsor
Steve Burger's Avatar
Tell the converter company you will use this is for an LS1. They will make the converter with an LS1 pilot. It will bolt right up.
I have a 4200 stall converter for sale if you are interested. It is a bolt in.
Old 01-18-2007, 12:26 PM
DanZ28's Avatar
Like Steve said. Several companies will a make an LS1 to TH400 specific torque converter. It's basically an LS1 converter with a longer snout to the transmissions front pump.
Dan
Old 01-18-2007, 04:48 PM
Vcious04's Avatar
Here's what I used.. Works perfect..
Hughes part #HP4004 (Flexplate)
Hughes part #HP3795 (Flexplate Adapter)
Quick Reply: T400 Swap. Which Converter Flexplate
