A4 Cooler Line Question
I am installing a transmission cooler inline with the stock one in the radiator. I would like to make this as "bolt on" as possible, without having to cut the hardlines. Is there a fitting to allow the standard hard transmission cooler line to be adapted to a standard AN line and a fitting to convert the radiator fitting to an AN connection? Anyone have something like an aeroquip part number?
Thanks
Thanks
LS1Tech Administrator
Received 1,492 Likes
No need for all that work, IMO. The stock cooler return line has a portion that is rubber, that clamps to the stock hard pipe right near the radiator. All you need to do is remove the stock rubber line from the stock hard pipe and connect the aftermarket cooler there. This is how many people install aftermarket trans coolers on LS1 cars.
