what should I do
Old 01-25-2007, 10:55 PM
orangefun's Avatar
Default what should I do
if any of you have seen some of my more recent threads in here then you know my flex plate is gone and my starter. no biggie I got new ones plus a 3500 stall, so far I got a trans go hd2 shift kit for it and put a huge cooler on it, and got a new filter and pan gasket. is there anything else I should do or be aware of while I have the car 2.5 feet in the air and the tranny on the work bench?
what are flexplate and, tranny to engine torque specs?
Thanks
Old 01-26-2007, 09:45 AM
02NHRAtransAm's Avatar
Well we aleady took care of you havind 2 feet of nitrous line rolled up by your headlight, so i would say you are good to go
Old 01-26-2007, 08:52 PM
DrkPhx's Avatar
Thanks
Didn't see your previous thread. What happened?
Torque specs:
Converter to Flexplate - 44 lb ft
Flexplate to Crank
1st pass - tighten in sequence to 15 lb ft.
2nd pass- tighten in sequence to 27 lb ft.
3rd final pass - tighten in sequence to 74 lb ft.
Old 01-27-2007, 11:40 AM
Torque specs:
Flexplate to Crank
https://ls1tech.com/forums/showthrea...00#post6279500
there ya go
