code P0757 again, but solenoid is new?
I had both of the solenoids replaced when I had my tranny beefed up,
they replaced the band, solenoids, sprags,
well it was done because the car threw the code for the solenoids being stuck open, but now it just did it again but they're both brand new,
WTF? could it be a tuning issue?
pat
pat
LS1Tech Sponsor
you can also get that code over stuck valve or a bad manifold presure switch ,I have that issue once the code would set intermitantly only after driving a bit , when i pulled the valve body because i knew the solenoid was good , I found that the valve behind the solenoid was dragging just slightly in the bore , I imagine it got worse as it got warmer, anyway i polished out the bore and valve and after that it was fine,
__________________
