TPS and trans C5 corvette
LS1Tech Sponsor
Yes the tps is used in shifting it tells the PCM throttle position which helps the PCM determine shift points and lin presure , but if the signal is not available the PCM will use the other information it has RPM MAFF VSS to control these things though they will not be as acurate and shift charateristics will be some what different
__________________
