bolt length for pilot spaced flexplate for th400/350
Old 02-22-2007, 06:39 AM
Frost's Avatar
Default bolt length for pilot spaced flexplate for th400/350
So I need a pilot spacer to run my traditional th400 stall I'm told... Well the ARP flywheel hardware I ordered was 11m by 1.5"long. They have nothing in 11mm that's longer that I could find...
Will these be long enough? What did you guys do?
Old 02-22-2007, 10:03 PM
blkbird_WS-6's Avatar
The bolts will be fine. Your pilot spacer will go inside of the flexplate after it is installed. The converter will then fit into it when the tranny is installed.
Old 02-23-2007, 07:13 AM
Frost's Avatar
Nice, thanks!
Old 02-23-2007, 05:59 PM
LS1MCSS's Avatar
Just in case you want them, here is the GM p/n. 12563533
Old 02-27-2007, 06:40 AM
Frost's Avatar
That's a number for EXTENDED hardware?
Old 02-27-2007, 12:02 PM
LS1MCSS's Avatar
http://www.sdpc2000.com/search.asp?s...acer&doquery=1
