Help
Old 03-22-2007, 03:23 PM
SSkillz's Avatar
Default Help
Im putting a converter in my car its a pt4400 its going good till i put the flexplate on the vert it gets hard and wont move to put the other bolts in.. is there a diffrent flexplate or do i need some kind of spacer. Any input would help thanks.
Old 03-22-2007, 03:39 PM
Custm2500's #1 Fan
silver-mod-o's Avatar
I'm assuming its for a 60E... turn and wiggle the converter on the input shaft of the trans... make sure its all the way in the pump and try again.
Old 03-23-2007, 12:31 PM
SSkillz's Avatar
OK now does the tc move easy or does it take some force to move it while its in the trans? I have it in right i use the measure about 1.0" depth thing and looks like its on right but if i try to spin it, it wont move freely you have to put some force on it. Im not sure it thats right or not could someone help me out!!
Old 03-23-2007, 01:10 PM
rbrcka's Avatar
I just put a new tranny/tc combo in my Camaro this weekend. I was able to spin the tc easily in the tranny to line up with the flywheel bolts.
Old 03-23-2007, 02:07 PM
zspot98's Avatar
It should spin easily, like said earlier it's not completely set onto the input shaft.
Old 03-23-2007, 02:42 PM
WE TODD DID's Avatar
The converter isn't all the way in the transmission. When its right, there will be somewhere around a 3/16 gap from the mounting lugs of the converter, and the flex plate. You'll have to pull the converter up flush with the flexplate.
Old 03-23-2007, 03:24 PM
SSkillz's Avatar
I guess i broke the pump Damn!!
