Roll/Coil Tranny Lines
I I need to replace my tranny oil lines and i'm looking to do it on a slight budget. If i buy prebent ones they are 75 plus oversize shipping. If i buy AL fuel lines [coils sold by summit] are those rated for oil as well?
They will work with oil no problem, but I have not had good luck with the U-make (double flare) fittings. They always seem to leak. I went with AN fittings and SS braided line, but on a budget I would do tranny-fluid-rated soft line. Get a parts guys that knows what he is doing, then read the side of the hose.
Jim
Jim
What type/where did you buy your braided cable from for your setup? I'm going with a braided fuel line since that is cheaper then running the prebent fuel lines for my car so maybe i'll have to scrap the budget for looks! Thanks for the reply!
